MadCAM with latest Rhino 8.10?
Hello Madcam users,
I have a report from a client MadCAM user that after they installed SR 8.10 that MadCAM stopped working. They were advised to uninstall 8.10 and reinstall 8.9 and MadCAM. After that it was working again. Anyone else using MadCAM have this problem?
In here madCAM works with every V8 Release including SR8, 9, 10, 11RC.
And we had no reports about madCAM not working.
OK, thanks Charles!!
The same client is also now reporting that they also have a problem with the latest Epilog laser software. Both of these started when he updated from 8.9 to 8.10. @stevebaer - did something change as far as printing goes between 8.9 and 8.10? Epilog works as a printer driver, and now when the user hits Print, the Epilog driver/software tries to start but never does (spinning wheel).
Or some kind of .NET framework incompatibility?
I am going to have them go back to 8.9 and see if that helps…
We made several fixes for epilog in 8.10. I’m actually surprised it was working for your customer before 8.10
OK, well, I sent him a link to download 8.9 and test. Something happened in the transition to 8.10 that made both his MadCAM install as well as his Epilog driver stop working. The MadCAM problem was confirmed by one of the vendors. It may have to do with the .Net version being used. I’ll let you know what he reports back on the 8.9 install.
