Hi
I want to create a simple macro to insert for example C:\Test.3dm
any help please?
Thanks
Hi
any help please?
Thanks
Hi Mad3d - Something like this should work:
! _-Insert "Path to file in double quotes" _Block _Pause 1 0 _Enter
Thanks Pascal
I figured out myself, the code is a bit diferent but they both work the same I guess.
!-_Insert C:\D5.3dm _Group _Enter _Pause _Enter _Enter _SelNone
What does the 1 and 0 in your code?
I see now, I did with enter and enter but I will change mine to 1 and 0 also, It´s safer
Hi, I have similar question… what if I want to insert it automatically to insertion point “0,0,0” ? Thank you
Hello -
! _-Insert "Block 01" _Block 0 1 0 _Enter
or
! _-Insert File=Yes "Path to file in double quotes" _Block 0 1 0 _Enter
Awesome, will try that. Thanks
