Someone found an answer to this?
My problem is the same, I’m trying to create a Macro for placing objects on a srf, and then after they’re placed, change their names.
But I don’t know how to place commands after _OrientOnSrf inside the macro.
Macros on commands that have several user inputs (orient with copy, curve boolean and etc…) have this problem.
I solved my problem using a different aproach, but I’m curious if this is issue was solved or “hacked”…
