Apparently you need another _Pause:
! _BooleanDifference _Pause _Pause _ShrinkTrimmedSrf _Hide
This is because BD expects first base object selection, and if there is preselection that first Pause is automatically ‘eaten’ by the command.
You might ask - how did I figure that out? F2 (command history) is your friend. After running the macro and failing I pressed F2 and got this:
Command: _BooleanDifference
Command: _Pause
Select surfaces or polysurfaces to subtract with ( DeleteInput=No ): _ShrinkTrimmedSrf
Select surfaces or polysurfaces to subtract with ( DeleteInput=No ): _Hide
Select surfaces or polysurfaces to subtract with. Press Enter when done ( DeleteInput=No )
Boolean difference in progress... Press Esc to cancel
Creating meshes... Press Esc to cancel
You can see from the above that despite the preselection, the first Pause gets ‘eaten’, and then when it comes time to select the second object(s), _ShrinkTrimmedSrf and Hide have already been ‘eaten’ so they don’t get executed.
Adding the second pause gets you this as a result when you pres F2:
Command: _Pause
Select surfaces or polysurfaces to subtract with ( DeleteInput=No ): _Pause
Command: _ShrinkTrimmedSrf
Shrunk 8 surfaces. 12 surfaces are already shrunk.
Command: _Hide
Of course this only works with a preselected group of base objects, so it will fail if they are not. To have something that works with either pre- or post-selection, you would need something like this:
! _Select _Pause _BooleanDifference _Pause _Pause _ShrinkTrimmedSrf _Hide
But in any case, if you have to undo the macro, you end up having to undo 3 operations. This illustrates the limitations of macros, and why, for most things that are multi-operation, I end up doing this with scripts. Yep, the learning curve is steep, but in the end you have a lot more power and flexibility.
