Is this command not macro-able? Select blocks, run macro to replace with a known block? I can’t get it to work, can’t bypass the popup to pick the block to replace with…
Hi Jim - yeah… so the bit where you select from a list is the thing… would you like to be able to just type the name of the block in the second selection (the replacement)?
RH-72651 ReplaceBlock - make it scriptable
Yep…I mean I’m sure I can “script” this up but was like hey I can just make a macr—oh, no I can’t.
