just wanted to share this:
a simple macro to draw a cylinder with fixed Diameter and height. -_cylinder _pause _d 8 40
but please note that i do not like the “_d” but -_cylinder _pause _diameter=8 40
is not working.
any better trick to solve the conflict of
_diameter
(and _radius)
being a nestable command, but also an option in this case of _cylinder ?
@pascal
i would call it a (minor) bug.
or is there some fine-tuning to identify _diameter as an option in a macro ?
Heh - well, it depends what mode the command was last run in - I would say this is a buggish thing indeed because Diameter does not appear as an option if it was run as Diameter previously - that is why it runs the nested command, while ‘d’ is ignored, or runs a ‘d’ alias (here, the ‘d’ calls my alias for Copy > InPlace)
yep. but it does not make sense to have
once a radius of 8 and other time a diameter of 8
compared to other macros / commands with numeric / double options i would expect -_cylinder _pause _diameter=8 40
to work (which doesn 't )
or any other approach that the numeric input always adresses the diameter ?
