Mac rhino v6 wip, bugs
Here’s a simpler test file with By Layer print widths.
It was a test to see if Grouping had any effect and it doesn’t seem to.Line Width Group test.3dm (3.5 MB)
It prints correctly in Raster and Vector to PDF.
Nesting the layers didn’t cause a problem either.
Hi, Thanks for your help and tests,
im not sure what else I can do this end, as It does not work on my computer running the V6 WIP, but works perfectly fine in V5…
regarding layers and print widths, Yes. only had one layer assigned with a print width. but I don’t see why that would make a difference to whether it works or not?
Also, I still have the issue with the deformed lines as originally shown.
Thanks,
Andrew
I’m surprised too.
The only thing I can guess is I’m using a newer build than you are.
I get new in-house build every day. I can have as much as a month’s worth of updates and changes that you don’t see for a while.
I did find and log a tangential bug I found as a result of this testing.
If you assign a printed line width to layer “default”, it does not stick.
If I set a different width to another layer later, then Default uses that different width even though it is set to something else.
Sometime next week (Wednesday or later), a new WIP should go out see if you can print the little boxes file both Raster and Vector to PDF and get line widths.
Thanks
HI,
ok, cool, look forward to that update, and trust that resolves some of those issues… The new version looks great, and can’t wait to use it full time, but for the moment need to stick to V5 for these reasons… so fingers crossed it works for me next week! : ]
I had not noticed the default layer not keeping its print widths, seems like a strange sort of bug.
When the new release is out I will try it out and post how I go with my lines.
Thanks
It is far too soon to be using the WIP for production work.
That warning should be very clear to everyone that touches it.
As the development process continues, and more people are willing to mess with it, the bugs will be found and fixed.
When the new builds come out, the specific fixes are listed in the discussion forum announcement.
Hi Philip -
Hmm - I’ll see if I can reproduce this (cannot so far) - the new way, however is to use Isolate/Unisolate rather than Invert/Hide (which ought to still work…)
Hi Pascal
That will probably be hard - it’s quite random, unfortunately…
Aah, you’re right. I forgot about that new command.
Thanks!
Philip
Just upgraded to Mojave and installed Rhino 6 WIP. My views have lots of converging lines maybe like perspective or raytrace lines? Is there a setting or preference that came over from Rhino5 incorrectly?
Could you try uploading that picture once again? It didn’t quite make it…
Updated. Thanks!
That looks like the issue that we have logged for systems with a Intel HD 4000 GPU - see RH-49356.
Could you run the Rhino SystemInfo command and paste the result here?
Yes, I have the HD 4000 GPU
Rhino 6 SR12 2018-11-27 (Public Build, 6.12.18331.12056, Git hash:master @ 741b185a2224361744ebc400f77bcaacb77e22d0)
License type: Beta, build 2018-11-27
License details: Cloud Zoo. In use by: rhino3d ()
Expires on: 2019-01-11
Apple Intel 64-bit macOS Version 10.14.1 (Build 18B75) (Physical RAM: 8Gb)
Mac Model Identifier: MacBookAir5,2
Machine name: HerbAdmin’s MacBook Air
Language: en-US (MacOS default)
Intel HD Graphics 4000 OpenGL Engine (OpenGL ver:4.1 INTEL-12.2.17)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Vendor Name: Intel Inc.
Render version: 4.1
Shading Language: 4.10
Z-Buffer depth: 24 bits
Total Video Memory: 1536 MB
Graphics: Intel HD Graphics 4000
Displays: Color LCD (128dpi 1x)
Screen size: 1440 x 900
USB devices
Apple: Internal Memory Card Reader
Apple Inc.: Apple Internal Keyboard / Trackpad
Apple Inc.: Bluetooth USB Host Controller
Apple Inc.: FaceTime HD Camera (Built-in)
Bluetooth devices
None
Third party kernel extensions
com.rim.driver.BlackBerryUSBDriverInt (0.0.74) 18378BE7-8E39-EE32-58BF-0DD52AA71357
com.sophos.nke.swi (9.7.4) AFB9B66E-C67A-32D1-A8A8-654F475EECFC
com.sophos.kext.oas (9.7.4) FE151087-F3B0-3F51-BD15-3313B8BCDDAB
Third party plugins
None
Rhino plugins
/Applications/RhinoWIP.app/Contents/PlugIns/RhinoBonusTools.rhp “Rhino Bonus Tools” 6.12.18331.1002
/Applications/RhinoWIP.app/Contents/PlugIns/NamedPositions.rhp “Named Position” 6.12.18331.1002
/Applications/RhinoWIP.app/Contents/PlugIns/PanelingTools.rhp “PanelingTools” 6.12.18331.1002
/Applications/RhinoWIP.app/Contents/PlugIns/AnimationTools.rhp “AnimationTools” 6.12.18331.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp “IronPython” 5.1.2015.132
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp “Commands” 6.12.18331.12056
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp “Grasshopper” 6.12.18331.12056
/Applications/RhinoWIP.app/Contents/PlugIns/Alerter.rhp “Alerter” 6.12.18331.1002
/Applications/RhinoWIP.app/Contents/PlugIns/Displacement.rhp “Displacement” 6.12.18331.1002
/Applications/RhinoWIP.app/Contents/PlugIns/RhinoRender.rhp “Rhino Render” 6.12.18331.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp “RDK_EtoUI” 6.12.18331.12056
/Applications/RhinoWIP.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp “RhinoCycles” 6.12.18331.12056
/Applications/RhinoWIP.app/Contents/PlugIns/NamedSnapshots.rhp “Snapshots” 6.12.18331.1002
/Applications/RhinoWIP.app/Contents/Frameworks/RhMaterialEditor.framework “Renderer Development Kit” 6.12.18331.1002
Thanks for that information!
The issue is actively being worked on but we’ll just have to wait until they get it fixed…
