I discovered that viewport performance (fps) is drastically dropping in rhino 9 beta after creating or editing any type of geometry (surface, polygons, subds, curves…). It gets pretty choppy to navigate the viewport in this state. Performance gets back to normal after switching to another app or minimizing Rhino and then returning to it.
Open Rhino 9 Beta
Rotate around the vieport and observe
Create any kind of geometry, for example a subD plane, maybe move around a few polygons
Rotate around the viewport again and observe drop in fps
Apple macOS Version 15.7.9 (Build 24G830) (Physical RAM: 32GB)
Mac Model Identifier: Mac14,10
Language: en-DE (MacOS default)
.NET 10.0.2
Metal GPU Family Apple 7
Metal GPU Family Common 3
Metal GPU Family Mac 2
Graphics processors
Apple M2 Pro
Color LCD (1728 x 1117 @ 120.00Hz)
GPU Vendor: Apple
/Users/amannvin/Library/Application Support/McNeel/Rhinoceros/MacPlugIns/SpeedengMacPlugin/SpeedengMacPlugin.rhp “UVMTools” 4.3.0.0
Hey Dan,
thanks for the reply. I’ve disabled the mentioned plugin, no change.
I’ve also tried to verify using “TestMaxSpeed” command (before and after adding/editing geo) and interestingly enough, it shows no significant change (119 fps vs 117.5 fps).
After comparing settings between Rhino 8 and WIP I’ve came across a new setting in WIP under Settings > Files > “Save multiple versions using macOS Versions (recommended)”. This was turned on by default.
After switching this to “Save only latest version of the file” and restarted Rhino viewport acts normal as expected.
Edit: This also improves my viewport performance after edits in Rhino 8 when deactivating this in the advanced settings (Rhino.Options.FileSettings.AutoSaveVersionsEnabled). But the difference is not as drastic as in WIP.
When you have a chance, it would be helpful to get a file from you, so we can try to duplicate the issue here.
You can upload it for us here, and include the link for this Discourse thread in the upload note.
There is another option that you can try. The command is Reset and it will roll Rhino back to default or “factory” install options. It is quite sever, and all customization such as Aliases and Display Modes that you have not saved will be lost.
You can also save your settings for support before you Reset and send us the Zip it the Reset fixes your issue.
If the Reset fixes the issue and All File Versions works, then we can run a dif on your settings and ours and see what may be inadvertently causing this issue.
Let us know if you are able to try this sometime.
Thank you for your help.
Did a couple of tests after loading newest Rhino Beta.
Test scenario: Empty project > add curve with 3 points
Turning “AutoSaveVersions” back on —> Back to old bad behaviour. So RH-98423 did not fix this. Performance only gets back to normal after saving the file (but then again after another edit, it’s back to being choppy)
Factory Reset (AutoSaveVersions again enabled by default) —> Same bad behaviour. Only saving the file (cmd+s) temporarily restores viewport performance
Turning “AutoSaveVersions” off after factory reset ----> Issue solved.
@dan I use both mouse and trackpack. The choppy viewport performance is definetly way more noticable when using the trackpad because of the “ease-out motion” it normally delivers (letting go of the trackpad midst rotating doesn’t stop the rotation immediately but it fades out).
With a mouse connected I have the same issue but it’s less pronounced (but still quite hard to work with). See screen captures below (one with trackpad, one with mouse)
Another note: I notice the same on rhino 8, but it’s less pronounced
Thank you @Vincenz this is quite helpful and gives very good clues.
We are having difficulty reproducing this internally. That said, everyone who has tested is on macOS Tahoe. I suspect macOS Sequoia is implicated in this bug. We have a MacMini running Sequoia, but no trackpad (which is also, I believe, implicated here). So I’m working on the logistics of setting up a testing system that can reproduce this.
@dan Actually since today my company mac now also is on Tahoe. The captured videos are already done on Tahoe as well so there’s no difference there at least.
I think we may indeed need to try with your Settings, as my coworker Mary requested. As she mentions, you can use Reset and cancel out - but click the Save Settings for Support… button. Please upload the saved the Setting zip here: https://www.rhino3d.com/upload and in the recipient field (2) just put dan@mcneel.com.
Can you please also include the SystemInfo from the Tahoe Macs that you used?
I wonder why this is so difficult to reproduce - your steps are very clear. I still feel like I’m missing something obvious.
Regardless, I doubt you are alone in experiencing this and we appreciate the help chasing this down.
Thanks for uploading those. No luck…I don’t think it’s the settings, but I’m glad we ruled them out. I still cannot reproduce it …yet. I’m going to try some other things though. Stay tuned.
@Vincenz I just noticed that your file lives at the following path:
~/Library/CloudStorage/OneDrive-
and that gives me a big clue. I bet cloud backup is implicated here. Can you try to reproduce the bug in a location that is NOT backed up to the cloud? (Keep in mind that people often have iCloud automatically backing up their desktop).
@dan This was one of my early suspicions as well (because onedrive often caused issues in the past…), which is why I tried saving the file in an non-watched folder as well as completely deactivating onedrive. TimeMachine is deactivated.
Still the only effective solution for me is to deactivate autoSaveVersions. Which is probably fine for me for now (as my files are usually backed-up through onedrive anyway).
What I also tested without luck:
Removing wacom drivers
Removing logitech mouse drivers
I’ll try to reproduce the issue on my colleagues mac today and let you know. If that’s the case we run something on our machines that causes this. (Our machines are managed)
@dan I believe, I’ve found the root cause. It wasn’t Onedrive but its evil brother Microsoft Defender. More precisely its background process wdavdaemon_unprivileged. I believe this is related to realtime protection/scanning.
When performing above tests (while autosave versions is enabled) and keep rotating the viewport this background process cpu usage spikes (up to 100%), which must cause the laggy viewport I’m seeing.
When autosave versions is disabled, the process doesn’t show cpu usage spikes.
As my mac is company managed, I can’t turn it off or change settings there to completely confirm this though.
This sounds plausible and some excellent sleuthing I might add. I’d love to be able to somehow simulate this condition - I doubt your situation is uncommon - and somehow at least warn the user. Maybe I can set up some similar analogous situation and trigger it.
