I’m trying to edit viewports that I’ve previously created in Layouts. I can select and move the viewport around ok. But I can’t shape change the viewport it as no grips appear on the border. Any suggestions please ?
all detail manipulation are equal to how Rhino works generally. you can use scale or turn points on then click on one point again to move it.
Thank you very much for your reply geemix. I’m afraid I’m not sure I follow what you said. Its the size and shapes of the viewports I’m trying to change, not so much the detail views inside.
Many thanks for answering though.
Hi Terry -
Unless you have customized your settings, when you select a detail on a layout, its grips will automatically turn on.
Apart from that, you can use commands such as Scale and Scale1D to change the shape of a detail.
Thank you Wim, those commands did work but ultimately I needed to change the shape. I can’t figure what settings I’m supposed to have changed which causes the grips to not appear. I’ve resorted to a workaround by deleting them and creating new viewports from scratch instead.
Many thanks for your time though.
