Hello Fellow Rhinos!,
I want to finally make the change to iMAC Mini for the hardware to run Rhino. I have been doing some research & it seems as though, technically the old M5 pro is statistically better, the new M6 chip is bettter at single thread processing.
What would you guys recommend? I also have an inkling, but in the future, to download & run a local LLM & integrate it into Rhino.
I use my system for Architectural drawings, blueprints, layouts, sheets, heavy hatching & fully loaded drawings & Tech Specs.
I am of the philosophy that it is better to not spend so much on local technologies, since advances seem to be leaps and bounds instead of investing thousands of dollars to future proof the hardware.
I am leaning towards the M6 chip, with a 24GB Ram option. Also, does the SSD size afftect the speed and performance of the system? I run all my files thourgh an excahnge server & a cloud.
Really hoping to pull the trigger soon, any advise helps.!
