I would very much appreciate if someone could explain this to me… I’ve attached files showing two tests I am doing with Lunchbox’s Hexagonal Panel component. It works perfectly in Test 1, but not in Test 2 and I have no idea why.
Please let me know if you can figure out what is wrong, thanks! Hex. Panels.gh (14.4 KB) Hex. Panels.3dm (2.6 MB)
hello Because your branching is different in the last outputs. Just check the branching of both curve. so Just simplify the output
What an amateur mistake… I had spent so long away from Grasshopper that I completely overlooked that. Thank you, I appreciate your help.
