Lunchbox won’t load with the latest update in Rhino Inside. Loads fine in standalone Rhino/Grasshopper. Also works if I roll it back to version 2023.2.2.0.
Is this the latest Lunchbox? I know there as been a lot of work being done lately to get lunchbox into the latest .net changes in Revit as well as Rhino.
Yep, 2024.2.9.0
I got the same issue. How did you roll it back to get Lunchbox working?
Thanks
package manager in rhino will let you uninstall the current version and select an older version to install.
you may want to disable auto updates so it doesn’t reinstall the current version when you open rhino the next time:
Thank you so much!
I have the same problem: lunchbox is installed but it’s not in the grasshopper feed
rhino inside latest rhino 8 and revit 2022
I’m seeing that as well. Try the earlier version and send a note to the developer, they are fairly responsive.
