Lunchbox install hangs on package manager - MacOS
Hi Guys,
I’ve been getting reports from KaroroCAM users of problems getting installed and running this week.
To check on the issue I pulled plugins off my MacOS test bed machine and started a from scratch install.
I use Lunchbox as a library in KaroroCAM, and when trying to install thru the package manager it stalls at 0%:
Been sitting like this for 30 min now - is there a problem with the file on the package manager?
Cheers
DK
Ok, turns out KaroroCAM was using a single component from Lunchbox which I was able to replace with three lines of python.
However my other plugin KaroroCAD I’m not so lucky with, it uses a bunch of not easy to replace components from Lunchbox.
Has anyone else seen this issue trying to install Lunchbox on MacOS via the package manager?
Cheers
DK
