I have published LunchBox for Rhino 9 which includes the latest builds of LunchBox and LunchBoxML for Grasshopper 2. (GH1 tools are also still included in this package.)
I am sure there will be oddities and bugs to squash in this transition but my test G2 definitions are loading up and are operational!
A new LunchBox G2 build is up on the Rhino 9 Package Manager with a few new components that aid in developing tessellated geometry with trimmed surfaces.
Panel Trim with Surface: Takes LB-generated panels and applies trims from a guide surface
Panel Pull to Surface: Takes LB-generated panels and adjusts curvature to match a guide surface
Panel Trim Edges: Takes panel surfaces and applies an offset trim around the perimeter.
Panel Thicken: Takes LB-generated panels and applies a thickness using local normals from a guide surface.
Structure Pull to Surface: Takes LB-generated curves and adjusts curvature to match a guide surface
Structure Trim With Surface: Takes LB generated curves and applies trims from a guide surface.
Structure Rectangular Pipe: Applies a rectangular cross-section and sweeps it along a curve with orientation based on local normals of a guide surface.
Rotate Surface UV: Takes an existing surface and rebuilds it based on approximated rotation of the UV parameter space.
Note that some of these components can get computationally expensive (involving trimming, evaluation, rebuilding, of lists of surfaces.).
@archinate1 Is there a way to make LunchBox for Rhino 9 load only in Rhino 9 based on the relevant SDK, while keeping LunchBox for Rhino 8 available only in Grasshopper 8?
At the moment, GrasshopperDeveloperSettings appears to be shared across all Grasshopper versions, so the settings are applied simultaneously and cannot be configured on a per-version basis.Also, thank you for your useful plugin.
