I first designed the base model in solidworks as thats a software I am mostly comfortable with and then brought that into grasshopper. I isolated the front face and tried using delauny triangle mesh but did not work as well as I expected.
Would like to know if someone has a good process to target this design. I have attached my grasshopper file which does not have much to show honestly.
I plan to 3D print the shell on a desktop 3D printer and cast it with concrete.
Does this mean âhuman-generatedâ? Anyways, if yes/no (), why not put through Vizcom, get a mesh, and 3D-trace it manually, similar to what @dfytz1 said, or try to reduce the mesh to get a âlow polyâ.
Thatâs also because the hope is for something automagic?!
A simple yet still true exploration (@Hussain1) could entail making a Y (text object) in Rhino, tri-meshing it and playing with vertices*: low-poly-Y.gh (17.4 KB)
