For some reason I keep getting missing files messages.
Is there a procedure to reconnect the file paths?
Thanks
Hi -
Isn’t there an option on the dialog that you are getting?
Please run the Rhino SystemInfo
command and copy-paste the result here.
Thank you
Rhino 7 SR12 2021-11-9 (Rhino 7, 7.12.21313.06341, Git hash:master @ 5590153808223b57a9f41516a969fd949aa81bff)
License type: Commercial, build 2021-11-09
License details: Stand-Alone
Windows 10.0.19042 SR0.0 or greater (Physical RAM: 7.7Gb)
Primary display and OpenGL: Intel(R) Iris(R) Plus Graphics (Intel) Memory: 1GB, Driver date: 4-12-2021 (M-D-Y). OpenGL Ver: 4.6.0 - Build 27.20.100.9510
OpenGL Settings
Safe mode: Off
Anti-alias mode: None
Mip Map Filtering: Linear
Vendor Name: Intel
Render version: 4.6
Shading Language: 4.60 - Build 27.20.100.9510
Driver Date: 4-12-2021
Driver Version: 27.20.100.9510
Z-Buffer depth: 24 bits
Total Video Memory: 1 GB
C:\Users\heeyo\AppData\Roaming\McNeel\Rhinoceros\packages\7.0\IntelDenoiser\0.6.0\IntelDenoiser.Windows.rhp “IntelDenoiser.Windows” 0.1.0.0
C:\Program Files\Rhino 7\Plug-ins\Commands.rhp “Commands” 7.12.21313.6341
C:\Program Files\Rhino 7\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 7.12.21313.6341
C:\Program Files\Rhino 7\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 7.12.21313.6341
C:\Program Files\Rhino 7\Plug-ins\RhinoCycles.rhp “RhinoCycles” 7.12.21313.6341
C:\Program Files\Rhino 7\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 7.12.21313.6341
Hi -
Your computer is severely underpowered to be running Rhino on, but that shouldn’t influence what you are experiencing here.
Can you post a screenshot of the dialog that you get when you are told that there are missing files?
Yes, which is why I’m searching to see if a remote solution like Paperspace or Azure would work better than my laptop.
Here is a screenshot of the message I get.
Thanks for your help
Hello - try running DownloadLibraryTextures
@wim Hi Wim, do you think that adding Ram to my laptop would make any difference? Or is it a waste of money?
Hi -
As the main problem is with the GPU, that would be a waste of money, yes.
