Lost keyboard shortcuts
My computer has been crashing all day, and the latest result is that all my keyboard shortcuts are lost. I’m wondering where those are kept, and if I can recover them from a computer backup or something.
Hi Peter - normally they’d be in
C:\Users\USER\AppData\Roaming\McNeel\Rhinoceros\7.0\settings\settings-Scheme__Default.xml
(or named with a different scheme if you have one)
Thanks!
Hi guys - could you please explain how you were able to recover the shortcuts from the xml file? I’ve lost all my settings from a crash as well
Hi Luke -
When Rhino starts and that file doesn’t exist, or, perhaps in your case, is damaged, that file will automatically be created with all the factory-default settings. If your system regularly takes backup, you could locate that xml file in the backup somewhere and replace the current xml file with that backed-up file. That will restore the custom settings.
Thanks Wim,
I’ve got a backup from a couple months ago but should be the same old display settings with it, will try that now
