Hello, there are problems with the french version of the software that has some language stability issues. Some menus are in French and others in English and it is changing during my workflow. See the image below. Besides, I havn’t viewed the mirror command in the french version while it is in the english one. But I probably missed it. Can you check it ?
Thank you for the answer. You’re a very professional team.
Run _systemInfo and post the results, to begin with. A screenshot doesn’t do much.
If you do a search on this problem, you will find you should try running a Repair on your Rhino installation.
Thank you for the answer (not ironically this time). Here is the system info
Rhino 8 SR31 2026-5-6 (Rhino 8, 8.31.26126.13431, Git hash:master @ 5b2851018299581b3fafbac5702dc76a8694b298)
License type: Commercial, version 2026-05-06
License details: Cloud Zoo
Windows 11 (10.0.26200 SR0.0) or greater (Physical RAM: 31GB)
.NET 8.0.21
Computer platform: LAPTOP - Plugged in [98% battery remaining]
Primary display: Intel(R) Arc™ Graphics (Intel) Memory: 2GB, Driver date: 4-16-2026 (M-D-Y).
Integrated graphics device with 4 adapter port(s)
Primary OpenGL: NVIDIA RTX 500 Ada Generation Laptop GPU (NVidia) Memory: 4GB, Driver date: 3-31-2026 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 596.08
Integrated accelerated graphics device (shares primary device ports)
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 3-31-2026
Driver Version: 32.0.15.9608
Z-Buffer depth: 24 bits
Total Video Memory: 4094 MB
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.31.26126.13431
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rendu de Rhino” 8.31.26126.13431
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.31.26126.13431
C:\Users\gbio\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\PanelingTools\2024.8.20.677\PanelingTools.rhp “PanelingTools”
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.31.26126.13431
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.31.26126.13431
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.31.26126.13431
C:\Program Files\Rhino 8\Plug-ins\Calc.rhp “Calc”
I don’t know how to running a repair on my rhino installation.
In Windows (in English sorry) to settings->Installed Apps and find Rhino there, select “Modify”, then when the Rhino install wizard appears select Repair.
