after inserting a few pictures in a layout some pictures do not display after going from a modeling tab back to the layout. Using selpicture highlights the surfaces but I have to reload the pictures. (proving they are still in the drawing.) Layers are set to display in the layout views. Sometimes this problem beings when changing layer-states
if this is a video card memory problem. (images are small) is there a way to monitor / trouble shoot?
Windows 10.0.19044 SR0.0 or greater (Physical RAM: 64Gb)
Primary display and OpenGL: NVIDIA GeForce RTX 2080 (NVidia) Memory: 8GB, Driver date: 5-29-2021 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 462.75
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 5-29-2021
Driver Version: 27.21.14.6275
Z-Buffer depth: 24 bits
Total Video Memory: 8 GB
you can upload files for tech support using Rhino - Upload to Support . Make sure to copy a link to this discussion topic to the comments section of the uploader. @wim (and others from tech support) will be able to see the upload once it has been completed.
Also, maybe recording your screen where you show your predicament may help understanding what is going on. The video you could upload in the same way as your 3dm file.
