Loop over Groups in Python
Hello All,
I would like to ask if is possible to loop over a selection of groups?
for group in groups:
ā€¦
Ultimately, I would like to make a script that will first use the contour command (group = yes)
Afterwards to move each group on a different location
Finally use the command setpt and flatten everything
Thank you in advance!
See here for the (python) rhinoscriptsyntax commands relating to groups:
https://developer.rhino3d.com/api/RhinoScriptSyntax/#group
For instance you can use
for group_name in rs.GroupNames():
    # do something
Thanks Graham,
I checked the rhinoscriptsyntax before posting.
However i had the impression that GroupNames command was related to the groupnames :blush:
Yes but you can then use ObjectsByGroup(group_name, select=True) to select the objects and do something with them :sunglasses:
    group_objs = ObjectsByGroup(group_name, select=False)
    rs.MoveObjects(group_objs, ...# do something
Awesome thanks a lot!!
