Looking for Rhino.Inside Revit v1.36 RC4 (Revit 2027 Support)
Hi everyone,
I need access to the latest version of Rhino.Inside Revit (v1.36 RC4). I’ve just installed Revit 2027, and I’d like to avoid installing an additional Revit version just to enable WIP updates.
If anyone can point me to the correct download or share guidance, I’d really appreciate it.
Thanks in advance for your support!
Hi @clark_kent,
Latest available v1.35 should install on Revit 2027.
Please give it a try.
Hi Kike,
I already have RhinoInside.Revit_1.35.9607.16352.msi, but it still doesn’t work on my side.
Is there anything else I should try for Revit 2027, or is there a known issue with this build?
Best regards,
Hi Clark,
Are you using Rhino 8 or 9? Note that Revit 2027 is in netcore 10 so support for some 3rd party legacy plugins will be limited.
Do I need to install Rhino WIP? This is my current setup:
That looks ok for systeminfo. I don’t believe 1.30 is req’d
Are you running Rhino or GH plugins that could be conflicting?
I have the same issue. I use Rhino 8 and revit 2027 and i installed RhinoInside.Revit_1.35.9607.16352.msi. i don’t even have additional plugins. It shows in add in manager of revit 2027 but doesn’t get displayed as a tab.
Hi rajavarman,
Revit 2027 runs in .netcore 10 and can run into conflicts with Rhino/GH plugins compiled in older .net versions.
Lets troubleshoot by temporarily removing 3rd party GH/Rhino plugins
I’m experiencing a similar issue as well.
Rhino.Inside Revit v1.35 does not appear inside Revit 2027 on my system.
The installation completes successfully, but the Rhino.Inside tab/add-in is not showing in Revit 2027.
Has anyone found a solution for this issue yet?
Best regards
Hi Ghasem,
There have been a number of reports this week but no clear pattern or resolution.
At the moment it appears to be a conflict with a Revit Addon or Rhino / GH plugin.
  1. Verify all version (Revit, Rhino, RiR, Windows) are up to date.
  2. Isolate from 3rd party Addins in Revit
  3. Isolate from 3rd party Rhino plugins
  4. Isolate from 3rd party GH Plugging
  5. uninstall RiR, reinstall.
Hi @clark_kent,
Unfortunately, the web is not up to date on regards the latest available RiR installer download.
Please use this one to download the latest from here RhinoInside.Revit_1.35.9607.19178.msi
Hi Japhy,
Thank you for your response and suggestions.
I checked my Revit environment and wanted to share additional information:
I currently do not have any third-party Revit add-ins installed (other than Rhino.Inside itself).
In Revit 2027, the Add-Ins Manager detects Rhino.Inside correctly and shows it as loaded/enabled.
However, the Rhino.Inside tab/panel does not appear anywhere in the Revit ribbon interface.
As shown in the screenshot:
Rhino.Inside is listed inside Add-Ins Manager.
The Revit ribbon itself remains completely empty of the Rhino.Inside UI/tab.
This seems like the add-in is being detected by Revit, but the UI is not being initialized or displayed properly.
Best regards,
Ghasem Ariyani
This version worked fine
Thank you
RhinoInside.Revit_1.35.9607.19178.msi worked for me- thank you.
Hello the latest version v1.36.9651.16848 @ 06/09/2026 is not working. The RiR banner does not appear.
Hi Grigoriadis, are you up to date on Rhino as well? 1.32 is the current release.
Hello, this was the issue thank you
Hello again, the latest version crashed when I launch RiR
Is there a crash report generated? (from RiR ideally).
Note that Revit 2027 is running .netcore 10, if you have Rhino/GH plugins running .netframework, or in some cases slightly older versions of .netcore you will need to remove them to operate 2027.
Will Rhino 9 also run .NET 10?
