Looking for Efficent Type Testing and Type Conversion
The Question
I’m wondering if there is a more efficient way to check the type of IGH_GOO in order to cast it to alternative types.
Use Case
Given a list of GH_Goo items of multiple non-geometry types [ GH_Integer, GH_Boolean, GH_Number , GH_Time, ect], identify the type in order to specify the correct corresponding type within an external library.
Current Strategy
//'attributes' is a GH_Structure<IGH_Goo> with mixed data types
//'fs' is a FeatureSet defined by an external library
//retrieve the IGH_Goo item to try and identify the type of
var typeItem = attributes.get_Branch(thisFieldPath)[thisFieldIndex];
string fieldName= "typeItem's DataTable Column Name";
//sequentially try and identify the type with 'if' statments
if (typeItem is Grasshopper.Kernel.Types.GH_Number)
     fs.DataTable.Columns.Add(new DataColumn(fieldName, typeof(double)));
else if (typeItem is Grasshopper.Kernel.Types.GH_Integer)
      fs.DataTable.Columns.Add(new DataColumn(fieldName, typeof(int)));
else
       fs.DataTable.Columns.Add(new DataColumn(fieldName, typeof(string)));
// after FeatureSet DataTable Columns have been made with the correct type
// iterate over attributes and converting them to correct type
// then adding them to the DataTable
foreach (var thisAttribute in attributes.get_Branch(path))
      // 1) check DataColumn type
      //  2) convert attribute to corisponding type
      //  3) add converted attribute to DataRow
  if (fs.DataTable.Columns[fields[thisIndex]].DataType == typeof(double))
     feature.DataRow[fields[thisIndex]] = Convert.ToDouble(thisAttribute.ToString());
  if (fs.DataTable.Columns[fields[thisIndex]].DataType == typeof(int))
     feature.DataRow[fields[thisIndex]] = Convert.ToInt32(thisAttribute.ToString());
  else
     feature.DataRow[fields[thisIndex]] = thisAttribute.ToString();
Imagined Alternative
I imagen there would be a way to retrieve the IGH_Goo’s Type and then look that type up in a Dictionary for its corresponding value. Perhaps “enum GH_IO.Types.GH_Types” could be used along with “Enum.GetName()” to help? Here is an example below:
Dictionary<string, Type> typeMap = new Dictionary<string, Type> {
      { "gh_int32",  typeof(short)    },
      { "gh_int64",  typeof(long)     },
      { "gh_double", typeof(double)   },
      { "gh_decimal",typeof(float)    },
      { "gh_date",   typeof(DateTime) },
      { "gh_guid",   typeof(string)   },
      { "gh_string", typeof(string)   }
var fieldType = typeMap[ TypeOf(typeItem) ]; //The Magic 'TypeOf' Method I'm looking for...
string fieldName = "typeItem's DataTable Column Name";
fs.DataTable.Columns.Add(new DataColumn(fieldName, fieldType)); //'fs' is a FeatureSet defined by an external library
Other Disscussions on this:
You could create a dictionary using System.Type as a key and some delegate as value, then call GetType() on the data and get the matching delegate to invoke?
