Hey everyone,
I’m an architect and the Co-founder of ThinkParametric. Like a lot of you, I got sick of spending hours tweaking Vray or the render settings in Rhino just to get a decent concept render out the door. So, my team built a plugin to fix it called FastRender: https://www.fastrender.ai/
I’ve attached a quick video of the workflow. It takes your Rhino viewport and renders it photorealistically in about 2 minutes.
The main difference between this and generic AI tools: we engineered it so it locks to your actual 3D model, so it won’t hallucinate walls or screw up your spatial logic.
The brutal truth: It’s an early Alpha build. It will probably crash your session at least once. The UI is raw.
I’m looking for 10 users who are in the middle of heavy concept iterations to help me break it. I want to jump on a quick 15-minute Google Meet with you, walk you through the install, and watch you run a test on your own geometry. I’ll spot you 20 free renders for your time.
If you want to test it and don’t mind a few bugs, drop a comment or DM me, and I’ll send over my Calendar link.
Cheers,
Arie
