I’m having trouble lofting the curves in the geometry component with those in the move component. Both lists have 160 curves so I’m not sure why they won’t loft.
Thanks,
Omar
lofting two lists of curves.gh (131.9 KB)
Thanks,
Omar
You’ll need to graft your input curves and transform vectors respectively…
Thank you it worked perfectly.
If you don’t mind me asking, why did the vector also have to be grafted?
If you provide flattened list of curves, then Loft will create a single weird surface using the whole two list of curves instead of one by one…
Ah I see, thanks again.
