Lofting curves
hi
i am trying to loft this 2 curves, but the surface created always overlaps on itself
i used rebuild curve with dege 5 and 7 for my other curves and fit curve, however i cannot get it to fit within the boundary curve for this surface, pls help
lofting water surface.3dm (486.4 KB)
i am uploading the rhino as it shows the curves at 1m contours from each other before lofting
that would not work because the curve is bending around the corner. for loft to work easily the curves have to permit a perpendicular array of isocurves, otherwise it folds into each other like here.
why do you need loft at all? since there are several curves i assume you are talking about these two?
the only thing that works here because you are not planar is patch. for this you have to close both ends.
also those 2 curves are super heavy, do you really need degree9?
