Lofting between to Spirals not working
the problem is that I could not find any solution for lofting the ramp-surface between two spirals. It works when the inner spiral goes from large two small radius and the outer does the same. In this case I need different run width on my ramp, so the iner spiral should go from large to small and the outer spiral from small to large radius. I alredy tried to use Sweep 1 and 2, Patch, nothing worekd. Thanks a lot for your help.
I present the issue by pictures and the gh-file belowForum-LoftingTwoSpirals.gh (32.1 KB)
It seems it fails when the inner curve became the outter !! There is an intersection. Can you post the exact parameter that fails ?
Hi, I do not think that there is an intersection between inner and outter curve. Here are both examples (First parameters are working). Second ones are
not working.
OK, the only solution I found is this one. It means building the surface from points in the curves.
Forum-LoftingTwoSpirals_LD2.gh (24.6 KB)
I think the problem is that Loft and other functions try too keep the connections at the same heights. Because they aren’t between the extremities it screwed the surface.
Thanks a lot for your time and the solution. I will try to continue with your solution. Does anybody else know why lofting fails in this case?
More simple solution but that has some flaws !
Forum-LoftingTwoSpirals_LD3.gh (22.9 KB)
Thank you, that is very helpful!
One minor qustion: Can you explain where I can find the component with the glasses-symbol and what it does?
This component is only used to show the names of components. It is useful when GH is in Icon model, which is my preferred mode.
Thank you!
