Lofting between the edges of two extruded curves
Hi, I have an extrusion and I have then scaled that extrusion. I want to loft between the edges of the extrusions to make a closed solid polysurface. Everything I’ve tried has had weird results. I think I need to isolate the outer circular edges somehow, but how? Thanks
You need to post a file or you will not get any help here.
Have you tried the Cap Holes component?
Thanks, how do I post a file? and what kind of file? would a screen
shot work?
Your .gh file with Rhino geometries internalized. Just pull the file into the text box and it will append.
