I am trying to loft between complex curves, and want to use grasshopper so I can make edits to parameters. The end goal is a lofted surface to be used in 3d printing, so it needs to be a one continuous wall. The object is a wicking plant pot, where the blue on Level A is a water reservoir.
I have been able to loft through a few of the levels in the image, but having trouble with level C. No matter what I try with seam adjustments, the loft is always a mess. My guess is because the curve is changing length.
The distance between the two walls in parts of the design is crucial, so I used the Fennec offset intersection so I can control the distance and have multiple offset curves. All the curves have the same number of points but the order gets out of whack.
I’m open to hearing any and all ways to approach this, in a way where I can still adjust the outer shape and the rest moves correspondingly.
I could share my gh file but it is basically:
outer curve (outside wall) → offset to create inner curves ->flip and adjust seam to line things up → join all curves ->divide curve → polyline → loft
Im new to grasshopper, appreciate any feedback!
Tom
