I want to basically make a whole automated system where you create objects from a data set, loft them, unroll them, then prepare the flat surfaces for nesting all inside grasshopper. So from start to finish grasshopper does everything… All i would do each time is change that data set at the start of the chain.
Is this possible or do I need to bake geometry throughout the process?
Cheers!
