"Lofting" above degree 3
rhinopython/spb_Loft.py at master · CADacombs/rhinopython · GitHub
contains three lofting methods:
  1. Standard: Uses Brep.CreateFromLoft.
  2. Iterative: Creates a starting surface then translates its control points until the surface’s Greville points match those of the curves within a specified tolerance.
  3. SrfPtGrid: Creates the surface using NurbsSurface.CreateThroughPoints with the option of adding columns of control points at the start and end of the loft for future continuity adjustment.
spb_Loft
