Loft through 3 curves
I want to loft through three curves and I don’t quite know how to go about:
I created a surface and then used a populate geometry item.
with that I created a multitute of points, I moved these points up and calculated the mid-point between them. Now, I randomly drew circles around the mid-points and drew circles with twice the radius around the original points on the buttom and the ones that I moved up.
Now what I want to do: I want to loft from the upper circle, to the one mid-ways (smaller diameter) and then to the bottom-circle. But I am confused with flatten and graft, I think. Or did I do it wrong all together?
thank you for your help.
2022_10_16_experiment with points and circles.gh (20.1 KB)
Graft each list and merge into a tree with 3 items per branch:
2022_10_16_experiment with points and circles.gh (19.5 KB)
thank you this is it!!!
