Loft/sweep problem!
Hi all,
I have 2 closed 3d curves and would like to make a loft.
but on few spots, the loft surface appear to be concaved (or curved in section). how can I fix this??
I tried Sweep2 rail but the same thing happens!
In Sweep2 you can use the Add Slash option to define the flow of the surface at a specific location.
Loft will try to “match” the two input curves according to their length, you have no control over how this is done. However, with Sweep2, you can use the “Add slash” button inside of the command to add directing sections to “straighten out” your sweep.
–Mitch
Thanks! it worked
Thanks Mitch! thats what I needed
Sameh
