Loft problem
Hello! Im new in this program and i have a problem that i can t figure out . when i use loft i ended up getting an object filled with lines instead a surface. help please
Can u post a screenshot or ur file? This is too general :d loft sometimes acts up
yeah,after 4 hours i figured out. click on “perspective” and click “Shaded” facepalm
U can also use middle mouse button to bring up the quick access menu… There u can easily toggle between views… Hover over each icon and it tells u what right and left click does… The gray sphere icon toggles between shaded and wire frame w r and l click…
U can also add any view u like by clicking on the margin of the q menu which will show u the gear icon that enables u to edit each button and add cmnds 4 r or l click …
If u go to the display tab… R click and go to edit button, u can copy the cmnd and then paste it in q a menu…i normally add shade or ghosted view to the r click of rendered view which is the blue sphere…
And if your problem is solved, click the Solution button in this case in your own post… Thank you
Thank you very much!
