Loft polylines to single polygonal surface
(or merge polysurface to single polygonal surface)
I need to create single polygonal surface from several polygonal profile curves (see .3dm files).
Loft command (with Straight section) generates polysurface, but I need single surface.
Reason is that the surface is to be exported to IGES and postprocessing tools depend on information about organization of individual patches in a grid.
Polysurface is loosing information about relation between individual patches, and they are exported as individual entities.
It is possible to Explode polysurface to individual surfaces, and Merge them one-by-one, but it is laborious to process several hundred patches this way.
Is there a simpler way how to make single polygonal surface?
polygonal 1 input polylines and polysurface.3dm (212.5 KB)
polygonal 2 input polylines and single surface.3dm (66.9 KB)
Run the command CreaseSplitting and set it to Disable. Then run your Loft. Beware, I would set it back to Enabled again after as this affects nearly every Rhino command that might produce creased surfaces instead of polysurfaces.
Thank you @Helvetosaur . It works, an your advice saved me a lot of work.
The command CreaseSplitting was introduced in V5 and I used it once long ago, but I completely forgot it exist. The state of CreaseSplitting is reset to Enabled after closing of Rhino, so I don’t need to remember to set it back.
