Loft Fails
Does anyone know why this loft isn’t working? Please let me know.
curves must be in a list flatten the curves input of the loft
i added a flatten tree between the extrusion and the loft and it still failed. is there anything else you would advise?
Post a file.
After flattening the list of input curves you have to add them to Loft in increasing (or decreasing) order - bottom to top, front to back etc.
FINAL ASSIGNMENT 3 BY YARA (1).gh (4.2 MB)
What you do here doesn’t make a lot of sense to me. Why do you provide extruded surfaces to the Loft component? It expends expects curves!
I was trying to create horizontal pipes or surfaces in that circle. Do you know how else i can do this?
hello, i tried this and it worked. thank you so much! but the lofted pipes dont start and end at the points of the cut out circle that i want to. do you know how i could fix this? i added the commands in the screenshot above to make the loft and didnt change anything from the script i posted above :slight_smile: please let me know
Loft Fails VR 1.gh (849.7 KB)
