Loft Failed
I would like to create a “loft” from 4 curves, but the result is not good
ko.gh (6.7 KB)
ko.ghx (210.8 KB)
I don’t understand why—could you explain the reason and suggest a solution?
Thanks in advance.
Have you heard of data trees and paths?
You’re basically trying to loft one curve with itself and the second branch individually.
Lofting 2 and 4 shows a result but not something I would want to use. With the curves being so much different at the front end, the loft will never be a nice surface.
It might help to add a sketch of how you think the result should look like.
Or do it in Rhino and then if you can’t replicate it in Grasshopper share the problem again.
Hi Martin,
Thanks to look my problem.
I heard data tree and paths…:-|…but ..
In the following script, you have the orgin form…and now i want to add an extend curve…
Base Form.gh (54.4 KB)
I don’t use these plugins.
Good luck
ok…cleaning done…:slight_smile:
I hope, it’s ok.
Base Form v2.gh (23.7 KB)
Dear Arthur,
Error messages:
Object ‘Graph Mapper’ {bc984576-7aa6-491f-a91d-e444c33675a7} failed to deserialize itself.
Graph Bezier2 could not be instantiated.
Looking at your .gh file, I see some basic issues:
  • Multipicating a domain is not possible, will give errror
  • Remap numbers, I don’t know what you use them for. This way it will not work
Please check/ redo these.
For your question here, best is to internalize what you have, just before the lofting, and upload that.
Regards, Eef
