I got error of “loft failed, dont know why”
but i know it happens because of number of items, in last part there should be just 11 curves but its more than that and i dont know why
thank you for your helpME2.gh (2.3 MB)
I didn’t investigate your definition fully, anyway there are a bunch of duplicate lines at the last…
You’d better not to create the cause of that duplication.
thank u so much, I didnt know how to omit them
I wanted to model ribbons that bend according to image sampler, but it seems in my model image sampler result repeat many times in one line
I don’t know what you are going to do, but if you modify your definition in terms of the data tree, it’s like the attachment IMO. See red groups.
it helps a lot, thank u so much…
Loft failed don’t know why error is usually related to
- Duplicated curves
- Start and end curve of the loft are the same, rather than using closed loft option
- You have curves which have duplicate control points on the ends.
