Loft elements between two lists?
Hello guys!
i want to make a stair and i am stuck at the last phase. I made to lists of curves and i just want to loft the elements of two lists each other. I want to loft first item of the first list with first item of the second list etc.
What am i doing wrong?
Stairs.gh (15.0 KB)
Like this?
Stairs2.gh (16.4 KB)
Thank you for your answer
not exactly this is the result i take…i want for example to loft the upper edge of the first surface with the down edge of the next surface
I wish I knew what you meant by “first surface” and “lower surface”.
ok let me try to explain…I have all these vertical surfaces. In this case you create a loft surface connect the same list edge and more specific the edge with index 1. What if i wanted to loft the edge with index 1 with the edge with index 3 of the next surface.
How’s this?
Stairs3.gh (17.8 KB)
yeah… this is what i want…thank you very much !!
