How can I loft the in-between space on a curved surface? The image is what I would like to do
Could you share your file, please. Are you trying to loft it in the same curvature as your initial shape, right?
You can split the original surface, using the curves, but its a bit of a heavy process. On my PC, it takes 12.5 seconds.
Hi Adam that seems to almost work, but how would I get the shape in-between the hex’s?
Nevermind done that! Thank you so much
