Hello, guys! I have a liitle problem with a tree. I tryed to make a loft between that points, but with every method which I tried, the result was a fail each time (I don`t know, probably nine, ten times). Can somebody help me with this or give me some advice regarding what should I learn? Exercices, tutorials, anything. Thank you in advance!
Loft between points? I donât know what that means? The yellow group in this version lofts each zig-zag line with up to eight of its neighbors. It doesnât make a lot of sense to me but is one possible way to interpret your intent? The âTree/List Viewerâ is just a tool for examining the loft results.
Thank you for the effort, Joseph! Really appreciate that! I want to do something similar with this. Maybe it helps and unfortunately is the single reference which I have.
Thatâs a complex pattern. I realize now I should have used four adjacent neighbors, not eight. Itâs hard to see how a âsidewaysâ loft like this can be a âClosed Brepâ (solid).
In my current definition, I do the rectangles with red, the âstarâ around these (green points) and now, the next step in my opinion is to do a loft between these points (green point), but not a continuous surface such as from ABCD which consist in extreme points of the geometry, something local because the next step after that is merge the all surfaces, close them below and maybe with this method I will have a Closed Brep, mesh it and celebrating the completion of this complex exercise.
I see four pairs of surfaces. And they are not from points, the edges that define them are lines, âVâ shaped segments of these eight point polylines you created:
Yes, you are right. It was a mistake from my side with that points. The loft option is based on edges. Thank you for the remark and sorry about confusion.
Actually, the way I see it now, the loft is between pairs of triangles. This isnât there yet but itâs close! Needs a little more work⌠Getting data trees to match can be quite challenging - and fun.
I took a brute force shortcut and one component is painfully slow (10 minutes) so will try to improve that before posting code. Every bit of this is a âClosed Brepâ.
This is reasonably fast at 12+ seconds. Long enough that you want to disable the slow part (orange group) while messing around with upstream parameters but not bad, considering.
Do you know why is happened? I mean, I just download the script, load it and the loft option is a little bit crazy. Do you what should I do? I see a flip or something like that. Maybe the version of Rhino to be the problem?
I have Rhino 6 too. I tried to solve this issue in this time, because I didn`t want to keep you too busy with this problem. I applied what did you tell me in red section, but the result is the same.
