Loft Command is creating line in top of object
When I use the loft command it is creating a line or seam on the surface of the finished object. The line is positioned where ever I set my loft starting points on my curves.
Just curious if there is a way of preventing this line or seam from appearing on the finished object?
Or is there a way to remove this from the surface afterwards?
Its causing an issue when I bring the object into my cam software, because it’s splitting the face as a result of that line.
I have attached an example of the object.
When I export, I am exported to a step file before I bring it into my Cam
Thanks,
Kent
Example.3dm (118.2 KB)
Hi @kentdesautel,
This is the seam of the lofted surface.
If you don’t want to see it, you can turn off tangent seams in on the display mode.
– Dale
