Locked Hatches Disappear in Model Space
I am having an issue where I have hatches in the model space and when I lock the layer the hatch is on or lock the hatch individually, they disappear. They are oddly still visible if they aren’t flush with an object but only on angles where the view doesn’t overlap the solid object.
Not sure if this is a bug or a settings issue. I’ve tried adjusting my display mode lock settings and haven’t had any luck.
systeminfo.txt (2.6 KB)
Hatch disappears when locked.3dm (151.4 KB)
Hi @isabella.sperling,
When a hatch is locked, Rhino draws it behind everything else so it doesn’t cover your linework in 2D drawings. In a shaded 3D view, that also puts it behind any surface it overlaps, even when the hatch is in front. That’s why it only shows where nothing is behind it. Your display mode settings don’t affect this.
For now, keep the hatch layer unlocked or switched to a Wireframe display mode.
I’ve logged this so we can look at it.
– Dale
