Hi Pascal
Well, its like a mix of things…
1] Firstly, I’m left handed, so I prefer the current column to be on the left, then the names, then on, lock, colour - the rest I don’t usually care about, and on V7, where its possible, I turn those columns off.
2] For some reason there is no visual dividing line in either V7 or V8, - the headings have a faint divider, but the actual columns don’t. What this means is there is always white space in the “current” column - the other columns are always filled with a name, or icons on, off and a colour swatch.
So in a long layer list, there is no “guard rail” to keep you out of the “current” column. Its like a painted line on a road is missing, so you tend to wander more…
3] Its pointless having the name of the current column actually written at the head of the column, because the name “Current” is wider than the Tick mark indicating which column is current.
So I tend to close that column width down, so I see “Cur” - I can close it further so the heading goes away, but then the column is really too narrow and there is even less indication its there.
Why not dump the tick icon, and the column heading and just make the indication of current layer a colour - perhaps the colour set for selection for example?
Further, make the whole column a colour, with a contrasting one being the actual current layer - then there is a solid indication that that column is used up. If this kind of colour information was exposed, I’d change it like that.
I’d go further - the current column is obviously tied to the layer name - you want to see that relationship. So why not just dump the present “current” layer column, and instead just make the current layer background highlighted?
Or leave it like it is in bold type, but change the colour of the text to the selection colour or whatever the user wants…?
My layer structure is often bigger than the screen allows, so it always has a scroll bar which I’m navigating up and down, so I’d make more mistakes than in a less dense one page structure.
I’ll try moving the current layer column off to the right after “color”, so that actual names are the first entry, and the “current” column is off out of the way.
But – a “hold” option that prevented the current layer being altered till specifically allowed via a right click would I think be an improvement……
cheers
rabbit
