Lock edges of patch surface?
Hi there,
Need to add organic form to a surface I’ve made via the patch tool, is it possible to lock the edges in place whilst manipulating the surface?
No. Trimmed NURBS surfaces don’t work that way.
Thank you, is there an alternative approach you can suggest?
Try SubD surface modelling. Or NURBS surface model what you want to end up with from the boundary curves, but that will be more laborious.
Thanks again, I’m having the same issue with subd.. the external dimensions are critical. seems like an obvious requirement..?
Then use NURBS surface modelling.
