Loaded fixed shelves on beam not working as intended
I’m trying to make a loaded beam with fixed shelves loaded on their endpoints.
The problem is that when I input more than one load the analysis behaves very strangely see below:
Also the eigen mode advice shows up in the entire process, while I already defined the points in my model, can someone help me with these issues?
Thanks,
Erik
Legno lamellare.gh (81.1 KB)
haven’t looked at the script as it contains 3rd party plug-ins. However make sure there is rotation stiffness around the axial direction of the main beam.
Thank you, that was a stupid issue indeed. Solved
