Load Error - Plugins
I repeatedly get these errors while starting up.
Can i get some help on fixing this please? I am unable to identify the plugins that are causing a problem , except for ironpython (which im not sure why i have in the first place)- frtomPriority: ProjectComponentPlugin
Exception has been thrown by the target of an invocation.
TargetInvocationException
Object: ProjectComponent_09dc24a5 (level 1)
Object: ProjectComponent_09dc24a5 (level 2)
Could not load type ‘Rhino.Runtime.Code.Platform.IProjectServer’ from assembly ‘Rhino.Runtime.Code, Version=8.25.25328.11001, Culture=neutral, PublicKeyToken=552281e97c755530’.
TypeLoadException
Object: Param_Block (level 1)
Object: Param_Block (level 2)
Bad IL range.
BadImageFormatException
Object: GetBlocks (level 1)
Object: GetBlocks (level 2)
Bad IL range.
Object: GetBlockGeometry (level 1)
Object: GetBlockGeometry (level 2)
Common Language Runtime detected an invalid program.
InvalidProgramException
Object: FindBlocksByName (level 1)
Object: FindBlocksByName (level 2)
Bad IL range.
Object: FindBlocksByMark (level 1)
Object: FindBlocksByMark (level 2)
Object: FindBlocksById (level 1)
Object: FindBlocksById (level 2)
Bad IL range.
Object: SetProjectInfo (level 1)
Object: SetProjectInfo (level 2)
Object: SetLocation (level 1)
Object: SetLocation (level 2)
Priority: GhpyLoader
The Rhino IronPython plug-in could not be loaded. It was either disabled, or it cannot load on your system.
ApplicationException
This looks like an Early Grasshopper plugins that is built for a pre-Rhino 8 version. What plugins are installed on this Grasshopper?
I see it has been a while since you have posted, so was wondering if it was fixed?
hi Scott, thanks for the reply!
it was ladybug, a blockmanager and a few others, I managed to fix it by uninstalling all plugins that i accumulated over the years and reinstalling a select few (which was much less fun than installing with package manager :slight_smile: ) i now get just no errors on rh7 but just one on rhino8 - for Ironpython. I am new to python and am jumping between versions of rhino at the same time.
spoke too soon! I now have all these errors, after installing pollination :frowning:
And now grasshopper seems to be disabled too
Hi Aditya -
For issues with Pollination, please use https://discourse.pollination.solutions
Pollination and LadyBug tools installation are such a disaster. The only help you will get here is the moderators refering you to the Pollination Discourse.
:neutral_face:
Which I suppose is fair.
shame, the plugin is so useul though. thank you
thanks Wim.
