I am stuck in trying to load a DLL library from inside a Rhino plugin written in C#.NET.
First of all, I have to say that if I write a simple console app and call the class exposed by the DLL everything works correctly, since the DLL was already registered by an installer that installed a software a registered many DLLs.
This is a 32-bit DLL. Maybe this is important.
Problems arise when I switch to a Rhino plugin.
I get the error
Class not registered (Exception from HRESULT: 0x80040154 (REGDB_E_CLASSNOTREG))
If I try with the good old regsvr32.exe I get this error
.dll was loaded, but the DllRegisterServer entry point was not found
If I try with regasm /tlb I get
RegAsm: error RA0000 : Unable to locate input assembly ‘myplugin.dll’ or one of its dependencies
I wonder why with a simple console app, simply adding a reference to the DLL, everything is working, while with Rhino it isn’t.
Thank you for any help.
