Lldb command error
I am working in the latest WIP (5E169w) and experiencing random (not reproducible 100%) crashes using the rebuild curve command. When I am adjusting the point count I sometimes get a crash with an error lldb command. Not sure what it is or why I am getting it. I did install it, but not sure why I need it.
I did report the crash using the crash reporter, but I wanted to share the dialog box after the crash.
Hi Jason - thanks I’ll try to reproduce this - what kind of numbers are you entering? Large? or ‘normal’?
Just clicking the up and down arrows on the dialog. Normal numbers. Just increasing it by a couple of points trigger it.
Yep, got it, thanks.
https://mcneel.myjetbrains.com/youtrack/issue/MR-3152
This crash should be fixed in the latest RhinoWIP (5E236w). Thanks again for reporting it!
