… the stop tick should be moved too.
Ciao,
Micha
Ciao,
Micha
I don’t get what you mean. Please explain. What and how do you delete? What do you mean by the ‘output length’ and/or the ‘stop tick’ and where should it be moved to?
An example - I delete 10 ticks and the animation end stick at tick 25.
Last I adjusted an animation by deleting/insterting ticks from time to time. The end of the animation doesn’t changed and I need to manual move it. The animation end could be automatic moved by inserting/deleting ticks.
I feel it is not obvious in each situation that the Animation-end-limit needs to be shifted also.
However a checkbox ‘include Animation limits stop tick’ might be a good idea. I’ll post an issue on YouTrack.
