ListView acess form command
I have the following problem:
I have a dockable panel on rhino, this panel contains a listview that is loaded inside the panel,and
the update method.
I try acess this listview items from a custom command that I made to update some items, the
problem is, how can I access this listview from the command?
I try inside command ex:
ClassList li = new ClassList();
li.update(some);
This dont work because is a new objet and not the same listview on ClassList.
So, Any idea?
Hi @MatrixRatrix,
If there is only one instance of your panel and it’s list control, then you might put an static Instance property on it, which returns the one and only object.
– Dale
Hello @dale, sorry dont understand.
I have a dockable panel form “SampleCsWinFormPanel.cs” , how I change this instance?
public partial class SampleCsWinFormPanel : UserControl
Thanks
@Dale,
Do not bother you, I already solved it.
